I have recently moved country from the UK to Germany and now that I am settled in I have decided that I want to make a PC to replace my ageing laptop which is slowly dying. Now as I have not built a system for a really long time, I mean we are talking when IDE cables and CD-ROM drives were state of the art, I figured that I should get some feedback before I actually buy the parts. This build will be done in stages with the first being just the basics with a budget of €800 - €1,000. As long as it doesn't cost too much I want to make sure it all looks good and matches with a red and black theme while also allowing freedom in upgrading in the future..
Initial build:
https://de.pcpartpicker.com/list/Zs4kzM
First upgrade set:
https://de.pcpartpicker.com/list/gkqfD8
https://linustechtips.com/topic/729581-pet-project/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (€209.82 @ Mindfactory)
Motherboard: MSI Z270 GAMING M3 ATX LGA1151 Motherboard  (€176.00 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  (€126.92 @ Mindfactory)
Storage: Sandisk X400 256GB M.2-2280 Solid State Drive  (€91.22 @ Mindfactory)
Case: NZXT H440 (Matte Black/Red) ATX Mid Tower Case  (€138.94 @ Amazon Deutschland)
Power Supply: BitFenix Whisper M 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€92.83 @ Mindfactory)
Total: €835.73
Generated by PCPartPicker 2017-01-27 23:49 CET+0100
made some revisions, got a better looking mobo, i would add in any cpu cooler of your choice, the thermaltake one you chose performs worse than a stock cooler, just a simple cooler master 212 will do, the powersupply is actually tier one @STRMfrmXMN (please confirm, on ur list it said bitfenix whisper but i put in the whisper m)
https://linustechtips.com/topic/729581-pet-project/#findComment-9273764
Honestly thought you were going to build something for your pet :(
https://www.youtube.com/watch?v=DMNSvHswljM
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/729581-pet-project/#findComment-9273788
4 minutes ago, tlink said:
you can ditch all of those coolers :P the stock intel fan is fine unless you want silence.
Yeah as far as I can tell the CPU from the vendor doesn't come with the stock fan, can't find it anywhere in the listing.
6
I was wondering if I should go for a Z270 but couldn't find one I liked, that one looks good. Yeah I was aware that the thermaltake wasn't a good one but was interested in the tech.
https://linustechtips.com/topic/729581-pet-project/#findComment-9273876
honestly, i would just put a i5 6400 in there until you can upgrade to z270 unless you have a big budget for that also
https://linustechtips.com/topic/729581-pet-project/#findComment-9281464
