Hi ,
i am looking to change my current case. i had the thermalLake v21, but i want to get a conventional mid tower now.
I have 3 things shortlisted -
1. NZXT H440
2. NZXT S340
3. Phanteks P400S tempered glass edition
4. Corsair Carbide 400C
Just a note - i have 4 HDDs and 2 SSDs to install, and i want a side window, and if it is tempered glass, even better. Compactness of case is also a consideration.
https://linustechtips.com/topic/729397-help-me-decide/
5 minutes ago, blnswamy said:
i have 4 HDDs
Well that rules out the S340
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271873
well if you have 4 HDDs then you can throw the corsair 400c out the window, only supports 2 full sized HDDs. Otherwise its a great case.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271878
Seems like a solid case and as you said, the tempered glass is a huge benefit. IMO it looks way better than a traditional side panel.
Ryzen 5 5600, 32GB DDR4, GTX 3070Ti, Acer Predator x34
InWin 901
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271882
BTW, can you post a list of your full system specs?
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271885
1 minute ago, blnswamy said:
https://pcpartpicker.com/user/blnswamy/saved/xMjwrH
i should have put this earlier
I would recommend the Phanteks Enthoo Pro TBH...
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271922
2 minutes ago, blnswamy said:
how many HDDs can you fit in this with extension brackets??
Phanteks says up to 6x 3.5" in their manual (page 5)
http://www.phanteks.com/assets/manuals/PH-EC416P_Western.pdf
InWin 901
https://linustechtips.com/topic/729397-help-me-decide/#findComment-9271950
