3.5 to usb not working
Hoads2047
I have recently bought a antlion 3.5mm to usb adaptor for my Audio technica MSR7's and my mod mic 4.0.
The modmic works fine on it. But the the sound comes from my PC. I know for a fact that that the headphones work because i have used them on numerous devices. and i have tried using different cables.
Please help.
Thanks.
12 minutes ago, Catsrules said:
You might need to go into the sound settings and set the headphone as the default audio device.
IS there a way to get it working in razer synapse?
get rid of that terrible software
  • 2 weeks later...
yes sir
Did the above solution work Hoads?
I've included a screenshot for reference of what you should be seeing.
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
Yes it did thanks
