I'm a new hand at this, but here are my hypothetical parts for the build. It'll be intended for 1080p gaming at high/ultra settings on most titles. The most important thing is for the build to be able to run No Man's Sky or similar games at 50 or 60 fps.
CPU - i5-6600K
GPU - GTX 1060 from EVGA
RAM - 2x4GB  DDR4 @ 3200 mhz (I think? Here's the link https://www.amazon.com/Ballistix-Elite-PC4-25600-288-Pin-Memory/dp/B01H3P9BY0/ref=sr_1_5?s=pc&ie=UTF8&qid=1485457430&sr=1-5&keywords=DDR4%2BRAM&th=1)
Motherboard - Gigabyte LGA1151
Power Supply - EVGA 500 W1 (rated at 500 watts)
Case - Roswell Micro ATX
Cooler - DeepCool CPU Cooler (This is the bit I'm most uncertain about. Not sure how to pick a cooler...)
Keyboard - AULA SI-859 (cheapest one on Amazon. Not mechanical, but that's not important to me.)
Mouse - Redragon M601 (again, cheapest on Amazon. I'm not a competitive gamer, so I don't need anything too fancy)
Headset - HyperX CloudStinger (Audio is important to me, and the reviews on this one looked pretty good.)
I already have a 1080p Acer monitor with a DVI connector that I plan on using. In future, I WILL want to upgrade to two or three monitors for productivity, although I'll still be using just one for gaming.
Overall, these parts come out to about 800 USD, with 500 of that being devoted in equal portions to CPU and GPU. I'm willing to work within the 800 USD, but would prefer not to go over that.
My questions are these: Are there any bottlenecks or glaring problems with this build? Is this an overly complex build for a first-timer?  Are there better parts I should be looking at for the same cost? Is a micro-ATX case too small?
Any help would be appreciated!
Everything I know I learned from the internet. Also school.
Current Desktop:
CPU: Ryzen 5 1600 @3.65 ghz, Cryorig H7
MoBo: Asus Prime X470-Pro
GPU: Gigabyte RTX 2060 Super OC
RAM: 2x8 gb Corsair Vengeance LPX DDR4 @2666mhz
PSU: 650W EVGA SuperNova
Storage: 120gb SK Hynix SSD, 240gb SanDisk SSD Plus, 1 TB 2015 WD Blue
Case: Corsair Carbide 100R
Peripherals: Logitech G Pro keyboard, Razer DeathAdder Elite, Logitech G305, Logitech G600, 24" AOC FreeSync 1080p monitor x2
https://linustechtips.com/topic/729012-800-usd-build-for-gamingprogramming/
the 6600k and 7600k are very similarly priced. what gives man. just get kaby lake.
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
Is a board for a Kaby Lake more expensive? The board I'm looking at says it supports 6th gen, but nothing about 7th. Will a Kaby Lake processor work?
Current Desktop:
The 6 gb model. I specifically want to be able to run Overwatch on high settings at 1080p. I'd like to also be able to run titles like Battlefield 1, Star Citizen, No Man's Sky, and Resident Evil 7, but if I need to drop settings to medium or even low for those, that's fine.
Current Desktop:
they are similar or just a bit more... the difference between z170 and z270 are pcie lanes (20x vs 24x) and intel octane technology.yes because they have the same socket so if you get a z170, you shouldnt have any troubles... but you will need to update your bios later. (also quote people or they will not see your answers))
i recommend now more to get a rx 480 8gb, so is eating gtx 1060 on every update
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
Thanks for the tip! I've heard that AMD cards tend to run a little hot, which causes some problems with thermals if your cooler isn't up to the task. Will that be a problem with the RX 480? Thanks for the info on the CPU, too. I have flashed a bios before, so that shouldn't be too much of a problem.
Current Desktop:
Use PCPartPicker. It will make yours and everybody else's life easier.
Since I am to lazy to put something interesting here, I will put everything, but slightly abbreviated. Here is everything:
42
also, some questions to make you wonder about life:
What is I and who is me? Who is you? Which armrest in the movie theatre is yours?
also,
Welcome to the internet, I will be your guide. Or something.
My build:
CPU: Intel Core i5-7400 3.0GHz Quad-Core Processor,
 Motherboard: ASRock B250M Pro4 Micro ATX LGA1151 Motherboard,
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory,
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive,
Video Card: MSI Radeon RX 480 4GB ARMOR OC Video Card,
Case: Corsair 100R ATX Mid Tower Case ,
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply,
Operating System: Microsoft Windows 10 Home Full,
Wireless Network Adapter: TP-Link TL-WN725N USB 2.0 802.11b/g/n Wi-Fi Adapter, Case Fan: Corsair Air Series White 2 pack 52.2 CFM  120mm Fan
ou do not ask why, you ask why not -me
Remeber kinds, the only differ between screwing around and scince is writing it down. -Adam Savage.
Only two things are infinite: the universe and human stupidity, and I'm not even sure of the former. - Albert Einstein.
