i don't know if this is the right place for this topic, but anyway,
i'm running fedora 25, and have windows 10 installed under virtualbox.
windows 10 can configure my ethernet adapter fine, with bridged network selected in the virtualbox settings, however,
my wifi interface doesn't work the same way. windows will keep saying identifying, and i cannot get windows online.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/728261-weird-virtualbox-networking-issue/
If you plan on using both adapters, go into Settings > Network, enable a new Adapter (Adapter 2), attach it to a Bridged Adapter, and select the wireless interface (wlan/wlp1s0/etc).
If this still causes your issue, try switching the adapter slots (wlan as Adapter 1, ethernet as Adapter 2)
nothing worked. now windows doesn't see anything. it just says no interfaces or something like that. i even reinstalled the guest additions and that didn't work either
EDIT: i checked device manager and it sees 2 internet controllers with no drivers.....
She/Her
try using KVM. its built into linux better and you can use it with gnome boxes.
i'm installing windows in gnome boxes now, hope it makes a diffrence
She/Her
