Hi so I recently finished my PC build, and it came out wayyy bigger than I imagined so I was wondering if I could return the PC and MOBo and build a mITX build. It says the refund button on Newegg but I was wondering what I needed to return (box etc)
Also for the case I wanted to go with a ThermalTake Core v1, but 10x10x12 wouldn't fit so I was wondering on any recommended cases? For refrence my old PC which fits with around 2-3" of space is 15" long, 11" tall and 4" wide (Also what would this form factor be called?)
One more thing, can someone explain mATX? the mobo I have is mATX so I don't know if I have to return it, because I thought mATX was just ATX but shorter.
Thanks!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/727619-return-case-mobo/
mATX is just a shorter ATX board. If you're still within the return period, then you'll have to pay a restocking fee and return shipping and youjust pack up whatever you want to return with whatever it came with and send it back.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/727619-return-case-mobo/#findComment-9252062
You can return the items back to Newegg, you just need to make sure that you return everything that came with your motherboard and case. You will most likely need the box that the items came in (shipping box) to send back to Newegg because you can't just send the item naked.
Also, if you want a case about that size, you would have to wait until the Dr. Zaber Sentry case is released. This thing barely meets your requirements are is one of the smallest that will be on the market. Anything bigger than this will probably not fit your area that you put your PC in.
http://zaber.com.pl/sentry/#home
Honestly, people say it's a shorter ATX (mATX), but the size is just a slightly wider and longer ITX because an ATX board is just way bigger and is more comparable to an ITX.
https://linustechtips.com/topic/727619-return-case-mobo/#findComment-9252094
