I would like to start a Vm server
I would like to be able to run the following:
A game server under linux (7 days to die)
freeNAS ( Network storage for the family) With Machine backup (Windows and IOS)
How do I set it up?
I was thinking
ESXi --) Freenas
         --) Linux (gameserver)
Do I need Vcenter??
https://linustechtips.com/topic/727558-help-me-get-started-vm/
PCPartPicker part list: https://pcpartpicker.com/list/6tvDhq
Price breakdown by merchant: https://pcpartpicker.com/list/6tvDhq/by_merchant/
CPU: Intel Xeon E5-2620 V4 2.1GHz 8-Core Processor  ($407.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L9x65 33.8 CFM CPU Cooler  ($46.95 @ Newegg)
Motherboard: ASRock X99 Extreme3 ATX LGA2011-3 Motherboard  ($159.99 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2400 Memory  ($169.99 @ Newegg)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  ($67.88 @ OutletPC)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($79.99 @ Newegg)
Video Card: PNY GeForce GT 710 1GB Video Card  ($30.99 @ Best Buy)
Case: Corsair 200R ATX Mid Tower Case  ($58.99 @ Newegg)
Power Supply: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($147.55 @ Amazon)
Total: $1398.18
Generated by PCPartPicker 2017-01-23 15:57 EST-0500
Hows this for a server?
lttstore.com
https://linustechtips.com/topic/727558-help-me-get-started-vm/#findComment-9251250
Total: $1398.18
I would say wayyyyyy overkill but I'm not OP :D
  • CPU
    Intel Core i7-7820X @ 4.2GHz
  • Motherboard
    Asus Prime X299 Deluxe
  • RAM
    32GB G.Skill TridentZ RGB DDR4
  • GPU
    GTX 1080Ti FE
  • Case
    Phanteks Enthoo Evolv ATX
  • Storage
    500GB 960 Pro SSD, 240GB PNY SATA SSD, 3TB WD Red NAS
  • PSU
    Corsair RMx Series, RM850x
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
    Razer BlackWidow Chroma "Clicky"
  • Mouse
    Razer Super Mega Black Mamba of Death 9000DPI
  • Sound
    Logitech Something with a broken bass adjustment knob so it's always rupturing spleens
  • Operating System
    NSA-Approved version of Windows 10 Pro
https://linustechtips.com/topic/727558-help-me-get-started-vm/#findComment-9251301
17 minutes ago, aeon187 said:
@Sauron
Isn't this esxi?
Yes ESXi is free, vCenter is the central management tool for managing multiple ESXi hosts. You still need to get a free license and apply it to the ESXi server and there are paid versions with extra features.
vSphere client is the legacy application used to connect either directly to an ESXi host or to vCenter, there are now website versions of both (running direct on the ESXi host or vCenter).
https://linustechtips.com/topic/727558-help-me-get-started-vm/#findComment-9251754
@leadeater Would you recommend installing ESXi on a small SSD or USB?
Since I have the SSD already can I use it to install ESXi and everything else on it, or it's better to have a separate physical drive from ESXi to VM?
Basically should I install ESXi on a flash drive or I can do it without any problem on that SSD?
https://linustechtips.com/topic/727558-help-me-get-started-vm/#findComment-9253247
I install mine on to a USB drive, nice and portable and keeps ESXi separate from VM storage.
https://linustechtips.com/topic/727558-help-me-get-started-vm/#findComment-9253313
