CPU too hot.
Go to solution Solved by itsmyjobtoknow,
6 minutes ago, SkyWarrior1030 said:
What is the impact of having a 4.4 instead of 4.5Ghz OC? Is it common for people to apply a 4.4Ghz OC?
Doesn't matter if it's common or not, if your CPU can't get stable at 4.5GHz with the max voltage you want to use, you got no choice but to do one of the option.
You will notice a minimal difference between the two clock speed.
Hello there,
I have been having an issue with my CPU overclock. It's an i7 6700k and I can only clock it to 4.5Ghz somewhat stably at 1.355v. Running the AIDA 64 CPU, Cache and FPU tests simultaneously caused the CPU package to hit over 80C. I am using a 240mm Thermaltake Water 3.0 AIO cooler. 70% of the time, my AIDA test stops itself one minute in as well. What could be wrong with my rig?
https://linustechtips.com/topic/727419-cpu-too-hot/
try decreasing the voltage by .025
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249684
2 minutes ago, SkyWarrior1030 said:
Hello there,
If the AIDA64 test is stopping itself...that is usually due to instability somewhere. Most likely your overclock.
You can either pull back on your Overclock and voltage (yields lower temperature), or add more voltage (yields higher temperature)
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249702
its very strange because it isnt a very high oc only a 7% increase from the turbo
My Stuff n' Things
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249717
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249721
4 minutes ago, SkyWarrior1030 said:
I have tried this OC with 1.34 all the way up to 1.355v. Anything lower than 1.35v crashes the system.
how about this, clear cmos, or load pre oc profile and start over.
My Stuff n' Things
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249735
https://linustechtips.com/topic/727419-cpu-too-hot/#findComment-9249780
