So after many problems yesterday, I manage to turn VGA_LED light off, but now I got new problem.
DRAM_Led is turned on, and I still have problem with monitor, with No video input, entering sleep mode.
Monitor is fine, its working on laptop, so one variable is ok.
I removed GPU, tried on integrated but still same message.
https://linustechtips.com/topic/727345-dram-led-flashing/
So the monitor is just not receiving a signal?
https://linustechtips.com/topic/727345-dram-led-flashing/#findComment-9249009
2 minutes ago, Trevor87 said:
Have you tried getting the latest BIOS for you board and installing or clear the BIOS on the board so it re install it self.
How can I do that?
I cant even find CMOS reset on mobo, its asus z87-c.
I have directkey, but what can i do when i dont have screen.
https://linustechtips.com/topic/727345-dram-led-flashing/#findComment-9249042
58 minutes ago, .50 said:
How can I do that?
Just take out the thing that looks like the watch battery on the mobo for a while then put it back in and restart
https://linustechtips.com/topic/727345-dram-led-flashing/#findComment-9249205
