Dynamode UPS 500VA Question
Go to solution Solved by W-L,
9 hours ago, xXxSourcexXx said:
Hey guys
I recently got my hands on a Dynamode UPS 500VA , and the question is can i hook it up to my rig ? i know it's an old model so i don't know if it compatible ?
I don't know a lot about UPS's , sorry for my ignorance , i use a 750W Corsair power supply
Thanks ahaid
What are your system spec we can get a better idea of what you need but that unit isn't that good as it's fairly low wattage (only 270W max) and a simulated sinewave, where I usually do not recommend lower than stepped simulated.
Hey guys
Thanks ahaid
AMD Ryzen 2600 / Asus Prime B-350 Plus / Asus Xonar Essence STX / 16 GB Kingston HyperX 2400 MHZ / Gigabyte 1070 G1 Gaming 8GB / Corsair DX850W / 250 GB 850 Evo SSD + 3TB (In Various Hard Drives) / Logitech G710+ Keyboard / Razer Abyssus Essential / Cooler Master HEF 932
https://linustechtips.com/topic/726898-dynamode-ups-500va-question/
3 hours ago, Himommies said:
Do you really need it
With the problem's that our Electricity Company is creating i do , do you think i can use it although it's an old model ?
Hey guys
Thanks ahaid
I don't even need to tell you the specs ; it's a very old UPS so i won't be able to use it , thanks for your help
