need help
Go to solution Solved by WoodenMarker,
1 minute ago, sergamer said:
under load its hitting 150 on my gtx 1070 and 140f on my cpu
Those temps are perfectly fine.
You're fine up to 80-90c at load on either. That's ~180f.
That being said, you should probably start using Celsius instead of Fahrenheit when it comes to pc components.
15 minutes ago, Technicolors said:
Do you mean 100 degree Celsius ?
The system would probably shut down if that was the case.
100f or ~40c is perfectly fine.
Idle temps don't really matter much though and you should focus on load instead.
https://linustechtips.com/topic/726771-need-help/#findComment-9242847
https://linustechtips.com/topic/726771-need-help/#findComment-9242859
https://linustechtips.com/topic/726771-need-help/#findComment-9242864
yea I can see that everyone else uses Celsius, and why does it seem so bad but its ok for temps to be that high?
https://linustechtips.com/topic/726771-need-help/#findComment-9242900
Your temps are normal.
https://linustechtips.com/topic/726771-need-help/#findComment-9242902
