I wanted to upgrade my gt 610 to a gt 730, so I had switched to integrated graphics, uninstalled the old drivers, and installed the new drivers. When I booted up my PC it stopped at the first windows screen, beeped three times, and then shut off. There are no compatibility issues apparently, Can someone please help me?
https://linustechtips.com/topic/726769-gpu-upgrade-problems/
Specs? What was the process you went through to swap the part? (from start to finish). Did you take any precautions from static charge and such?
https://linustechtips.com/topic/726769-gpu-upgrade-problems/#findComment-9242781
