Hello,
So I have installed these two different RAM kits into my computer and for some reason it will read a different amount of sticks with different configurations on the motherboard. It also reads in different lanes with different sticks and sometimes it wont it is very odd. Right now i have them in and it is reading 3 of them (out of luck) but the computer is not working well at all. I flashed my BIOS to the most current version and I also cleared the motherboard memory (took out the little battery and put it back) and tried many many different combos of having the ram installed and different ones work in different slots and not in other slots. should i just ditch these four and get a new kit? I had the series 4 for a year and everything was fine until now.  I'm afraid to try moving them around again cause most of the time it will only read 1.
My Rig;
Mobo: Asus X99-A USB/3.1
CPU: i7-5820k
GPU: MSI gtx970 gaming
Power Supply: 650 watts
SSD: samsung evo 256GB
HDD: 1TB something lol I forget
RAM: vvvv
Thank you for your help.
https://linustechtips.com/topic/725730-ram-problems/
Mixing RAM should work unless there's an issue with the CPU or motherboard. Have you disabled XMP and any overclocks?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/725730-ram-problems/#findComment-9232054
