Quick question. I have the Sapphire Radeon R9 390 Nitro. It has 2 6+2 pin connectors (not sure why we don't just say 8 pin, but sure). What I'm wondering is...well, I have a cord with 2 of the 6+2 pin connectors on it, but running through a single line to the PSU. Am I getting enough power this way? Should I run 2 separate 6+2 cords to the GPU from the PSU? Thanks!
Screenaninator: Sapphire Radeon R9 390 Nitro
Procrastinator: AMD FX-8300
Stickaminator: 16GB Crucial Vengance DDR3
Powermathingy: Corsair RM850i
attachamajiggy: Asus M5A97 R2.0 f
Remembrerthing: 240 GB Crucial SSD, 2TB Toshiba HDD
https://linustechtips.com/topic/725669-r9-390-power-setup/
5 minutes ago, nerdslayer1 said:
you should be good
Dang. I was kinda hoping that would explain why my performance is shit.
https://linustechtips.com/topic/725669-r9-390-power-setup/#findComment-9231246
2 minutes ago, nerdslayer1 said:
update all drivers
Already have. :/ Someone thinks it may be a mobo issue, and recommended clearing my CMOS. I tried looking it up, and it looks more confusing than anything.
https://linustechtips.com/topic/725669-r9-390-power-setup/#findComment-9231264
yes clear cmos. are you overclocked? also Locate the round, flat, silver battery on the motherboard and carefully remove it. Wait five minutes before reseating the battery. Clearing theCMOS should always be performed for a reason – such as troubleshooting a computer problem or clearing a forgotten BIOS password
https://linustechtips.com/topic/725669-r9-390-power-setup/#findComment-9231274
I saw that. That was for mobos with a BIOS. Mine involves jumpers, because I have UEFI. Fun stuff. And yes, I'm oc'd to 3.7Ghz on an FX-8300
https://linustechtips.com/topic/725669-r9-390-power-setup/#findComment-9231290
