This is version 1. Tell me if you think I have a chance or should I just stop.
The Idea:
I want to mount 2x quad 120mm radiators in the case. So all the mesh you see on the left front and left top will be covered by a radiator/fan sandwich. I'm making the case out of aluminium with 100% screw 0% rivets. It has two compartments. The window/left side is housing all the sexy components and watercooling whereas the other area is for the PSU, storage, and other components. I'm still working on the design. I want to divide the case according to the golden ratio. So what you see know is a 50/50 division. Furthermore. I haven't ploted any wire holes and grommets. I plan on using premade hardrive cages or possibly getting custom brackets printed. Trying to keep this case under $400. The front io plate is also aluminium. I will also try and add a usb. 3.0 SD card reader in there. I haven't settled on dimensions yet. Right now it's just my idea and concept.
Please share your thoughts!
CPU: Intel i5 3570k @ 4.0Ghz GPU: EVGA 660 SC - Awaiting Gigabyte 770 HOF MOBO: Asus p8z77-V Pro PSU: Corsair CX600 - Awaiting Corsair RM850 Storage: 750GB Seagate SSHD + 500GB HDD - Awaiting 250GB Samsung 840 EVO RAM:  16GB ( 4x4GB ) Crucial BallistiX Sports - Awaiting Crucial BallistiX Tracer 16GB Kit Case: NZXT Phantom - Awaiting Undecided Upgrade CPU Cooler: NZXT Havik 140
https://linustechtips.com/topic/72507-case-im-designing/
Are you going to be making the whole case out of ally or is it just the front panel?
Nevermind. I didn't see the part where you said the case is being made from ally. :P Looks pretty nice!
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/72507-case-im-designing/#findComment-993112
Bevel some edges and stick a handle on it?
https://linustechtips.com/topic/72507-case-im-designing/#findComment-993127
Currently I'm using Sketchup and I'm not completely acquainted with it. But yes, The edges are going to be rounded. Also the window and rad mesh is going to have rounded corners.
https://linustechtips.com/topic/72507-case-im-designing/#findComment-993171
It looks teeeeeeeeeeeeerribly big in my opinion.
Like I said, the measurements are exact. The 5.25 bays are out of proportion. Reference the 120mm mesh on the top and front.
https://linustechtips.com/topic/72507-case-im-designing/#findComment-993293
