Hello,
Let me get straight to the point:
I am invested into my computer as it is and I need the ability to run just about anything. That's it.
Scenario:
I am in High School currently and have a job where I will be needed to use Photoshop consistently.
I will be editing product photos for a website. I need to be able to complete each photo with the optimal
efficiency and quality. College is just around the corner and I am going to be majoring in Engineering and
Computer Science. So I need to be able to render objects and who knows what else. I want the computer to last
from now until the end of college and then some, if possible. Also, keep in mind that I love the occasional game
when streaming to my Nvidia Shield so a Kepler GPU is required.
Where I Need Help (Components):
  • Corsair 900D
  • 2x Western Digital Black 2TB
  • Asus PA279Q WQHD True Color Professional Monitor (2560x1440)
  • 2x ASUS GTX 780 DCUll 3GB (Probably needs changing)
  • Corsair AX1200i Full Modular PSU
  • Corsair K70 Cherry MX Blues
  • Razer DeathAdder 2013
  • Arctic Silver Thermal Paste
  • 32GB (4x8GB) or 16GB (4x4GB) G.Skill Ripjaws Z series 1866 RAM
  • ASUS Rampage IV 2011 X79
  • i7-4930K Unlocked Haswell Processor 2011
  • Samsung 840 EVO 240GB SSD
  • Water cooling for the CPU and the 780's
  • Blue Yeti Microphone
  • Sennheiser HD555 Headphones
Total Cost will be around $5700-$6000 US Dollars
The Problem:
I am still semi-inexperienced when it comes to what is necessary in a workstation
please feel free to offer suggestions on what to upgrade or downgrade so I will not be
wasting this much money on something I don't need.
Thank you.
https://linustechtips.com/topic/72502-workstationgaming-rig-please-help/
WAYYYYYYY overkill get a 4770k and a 6gb 780it when it comes out
Rampage 4 extreme is a waste trust me unless you are doing crazy LN2 overclocks it's pointless
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
3930k, asus rampage board, h100 or something similar (will leave it to fellow members to pick) 1xsamsung 250gb ssd, itll be cheaper and have the same write speeds because 128gbs tend to suffer in write speeds compared to 250gb drives).
get 4x4gb of ram, there arnt many things that benefit from more than 8gb of ram let alone 16 but whatever, quad channel is awesome.
get a corsair or seasonic 750w maybe 850, seagate 3tb drives..
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
Thank you for the charts. I might leave the other 4 slots of the quad channel open.
and the 4930k is only $40 dollars more for a better optimized platform.
I forgot to mention the water cooling will be a custom loop.
making changes in the original post now.
Why is the 4930K overkill?
And that's what I was thinking with the 780 ti
Keep it if you want X79 but it looks like a 4770k will be enough
If you do want to stay with X79 get a WS board or rampage 4 formula depending on use case
I am going to keep the 4930K just, for lack of a better word, "future-proof" the desktop even further.
 I just wish the formula had 8 slots for RAM for the ability to upgrade. A really compelling board for the price however.
What is the difference between the WS boards?
Did anyone see the new Rapage IV Extreme Black Edition?
Let me guess--your parents are paying for this?
What kind of work are you currently doing? On what scale? Programs being used?
Any examples?
The workstations boards are designed for 24/7 heavy load overnight renders and such and usually come with a better warranty
For future proofing X79 is good in terms of upgradability but keep in mind that the chipset will be quite "weak" soon
Any examples?
Haha I wish they were, but no coming out of my own pocket.
And like I said currently I'm editing photos for products on a website, however this PC is going to be with me in college when I am an engineering and computer science major. As of now I don't have specifics on scale or programs, but I want to the PC to be able to handle anything and everything.
There's a certain point where getting a slightly stronger system isn't worth it. Unless you're making money that's reliant on how quickly you can finish a project, you'll be better of with a mid/high end system and upgrade as better and cheaper parts come out.
Other than PS, what other programs do you use? Any examples of your work?
So what exactly is wrong with the setup I have mentioned? I see what you are getting at. However, I need a desktop I can rely on for the next few years. It may come down to an internship where, like you said, quickly finishing a project is the main purpose.
There are cheaper, better value parts that will do the job only a bit worse. It won't make much of a difference like you wouldn't be able to do a project or not. Just slightly faster renders and such.
Btw, you won't be doing any heavy renders in Engineering--mostly simple things and maybe a decent simulation here or there.
As for photo editing, any decent system will be fine unless you're doing absolutely massive pictures with many layers that puts 4k to shame.
If you're doing super heavy renders at an internship, you will most likely also have access to a render farm.
What parts are not worth the money in your case? Pretty much all of what you have chosen.
What do you need the Blue Yeti for?
As for the system , something like this should be plenty: http://pcpartpicker.com/p/1XGUJ
Btw, you want to quote a post or tag a member or else they won't get a notification you replied to them.
I would get an i7
