Hello, I'm building a PC Build and it needs to be able to run games at 1440p 60fps at High - Ultra and it would be nice if it could cost about 1.5K to around the 1.65k 1.7k Range
- 1440p 60fps
- High to ultra settings
- KBM (Cherry MX Blues or browns)
- 1440p monitor
- OS (10 Home)
- PCIe wifi card and a USB Bluetooth dongle
- Thanks Again Guys, Jamie
https://linustechtips.com/topic/725009-help-please-thanks/
i7, 1070. I'll let someone else give you a build. But I can help with the monitor. Here is my recommendation: http://pcpartpicker.com/product/7TrcCJ/asus-pb277q-270-75hz-monitor-pb277q
 If you need it to be cheaper (the build costs more than I expected): http://pcpartpicker.com/product/TwzZxr/asus-monitor-vx24ah
https://linustechtips.com/topic/725009-help-please-thanks/#findComment-9223482
- 1440p 60fps
- 1440p monitor
- OS (10 Home)
Get a 7700k with a gtx 1080 or gtx 1070 depending on ur budget
GG
https://linustechtips.com/topic/725009-help-please-thanks/#findComment-9223483
*obligatory*
Wait for Zen
/obligatory
Intel: 7700k / Z270 / OC'd 1070 / Tier 1-3 PSU / 8GB DDR4 RAM (speed unimportant)
everything else is up to you to choose based on your tastes.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/725009-help-please-thanks/#findComment-9223522
Thanks
https://linustechtips.com/topic/725009-help-please-thanks/#findComment-9223530
One question, is the monitor to be included in the budget, if so that makes both a 1070 and an i7 very difficult to fit into the budget. Otherwise this falls well within your $1500-$1700 price range.
https://pcpartpicker.com/list/6JKCM8
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor  ($344.75 @ OutletPC)
CPU Cooler: Corsair H80i v2 70.7 CFM Liquid CPU Cooler  ($89.88 @ OutletPC)
Motherboard: MSI Z270 SLI ATX LGA1151 Motherboard  ($139.99 @ B&H)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($103.22 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($91.99 @ SuperBiiz)
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($449.99 @ Newegg)
Case: Corsair Carbide 400C ATX Mid Tower Case  ($94.99 @ Jet)
Power Supply: Corsair RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.58 @ OutletPC)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ Newegg Marketplace)
Keyboard: Corsair STRAFE Wired Gaming Keyboard  ($88.99 @ Best Buy)
Total: $1671.35
https://linustechtips.com/topic/725009-help-please-thanks/#findComment-9223685
