I am looking for a case right now i am looking at the Corsair Carbide Series Air 540 High Airflow ATX Cube Case I love it but i am trying to save money on this build. I want the case to have good room behind the mother board for cable management. be a medium size case good airflow  with some fans with it similar io to the carbide. it should fit an asus saber tooth z87 an  Cooler Master Hyper 212 EVO a windforce gtx 770 and an  Antec High Current Gamer HCG-620M, 80 PLUS BRONZE, 620 Watt Modular Power Supply.
Also a durable as I will have to move it around a few times until i get out of college
Edited by Silencedelta
Asus G74SX,17.3" 1920x1080 Screen, Intel® Core™ i7 2630QM 2.2GHz, 2.9 Turbo, 12GB DDR3 1333 MHz SDRAM, NVIDIA® GeForce® GTX 560M with 3GB GDDR5 VRAM, 1.5TB (2x 750GB) 7200rpm HD Windows 7 Home Premium 64-bit. [] Asus VivoBook S400, Intel® Core™ i5-3317U Processor 1.7 GHz, 4 GB DDR3 1600 MHz 14.1" LED  (1366x768)  touch panel, 500GB HD, Intel® GMA HD, Windows 8 (64-bit)
https://linustechtips.com/topic/72486-what-case/
Whatever you're content to look at for the next 3 years.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/72486-what-case/#findComment-992772
Or hide under your desk and not look at for 3 years.
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/72486-what-case/#findComment-992775
I personally hate the Air 540 as there is no rad space where there should be, where the power supplies are located.
in the meanwhile, I think a arc midi R2/fractal define R4 are pretty good cases that are durable and light because they are largely plastic, I'd also look at corsair's low end as there is more plastic there so you can move your case around with out breaking your back like me with the 800D
https://linustechtips.com/topic/72486-what-case/#findComment-992804
I have and love the Fractal Design R4
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/72486-what-case/#findComment-992888
Most decent cases will fit your criteria.
So just pick a few you like the look of.
https://linustechtips.com/topic/72486-what-case/#findComment-993324
Dude, what?? The r4 Light and Largely plastic??
I have the damn thing, and its pure metal, just the door and the front panel are plastic, it's a pure heavy metal gorgeous looking case  :D
https://linustechtips.com/topic/72486-what-case/#findComment-993376
pure metal? go look at the outside, there's a reason why that case is light, it's faux brushed aluminum. I have a fucking full metal case, and it's the heaviest shit on the market
the inside it metal but it's still extremely light
https://linustechtips.com/topic/72486-what-case/#findComment-993429
