My first Triple-Monitor setup
Solved by m0k,
11 minutes ago, LawrenceBarnes2013 said:Should work, i think you'll just have black bars on the top and bottom of the 27". Never tried multi monitor setups, so it's just an analyse, process, judge sort of response.
-According to a topic i saw on Tom's, it shouldn't be a problem.
yeah you might have to raise the two 25inch monitors slightly to center it with the 27inch image
4 minutes ago, rypax said:okay thank you
