Is there a way to turn on a controller so I don't have to deal with so much of my camera flying. I just feel like this game is so much more suited for controller.
A smile goes much farther than the person it's meant for.
First impressions are important, it sets the stage for respect.
"If you don't know every word you don't know it!"- SGM McCray
https://linustechtips.com/topic/724151-help-with-mass-effect-2/
What do you mean by controller flying? The game does not support controller use, but there is a mod on nexus mods http://www.nexusmods.com/masseffect2/mods/62/?. If you dont want to deal with the mod you can change its config files. I forgot how you do this but a quick google and help with your mouse sensitivity. The game has a horribly consolized settings menu
https://linustechtips.com/topic/724151-help-with-mass-effect-2/#findComment-9213775
Will the mod work with origins file system?
https://linustechtips.com/topic/724151-help-with-mass-effect-2/#findComment-9213784
Just now, tp95112 said:
They both have the same file system. It should work. I havent used it but  its worth a shot
Thank you. It just kills me when you get a triple A developer who just cant figure PC players also sometimes want a controller.
https://linustechtips.com/topic/724151-help-with-mass-effect-2/#findComment-9213801
Yeah i know but I think it was on the original xbox if im not mistaking?
https://linustechtips.com/topic/724151-help-with-mass-effect-2/#findComment-9214595
