Static help?
Go to solution Solved by TheRandomness,
I've built a PC wearing socks on a carpeted floor. People worry too much about static, but just touch something metal every now and then.
Hi!
Today is the day I'm gonna build my first PC, and I want to be a safe as possible. I need some help with static so I have some questions
-I have a dog, I haven't touched him since I showered (few minutes ago) is there any thing I should do with him?
-What does "grounded power supply" mean?
-I've heard I had to touch un-painted parts of my case to discharge myself. So just checking all I have to do is touch the inside of the PC every few minutes?
-Should I wear shoes, sandals, or go bare foot? (I have a tiled floor)
-Any other safety precautions I should take?
Thanks!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/723885-static-help/
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/723885-static-help/#findComment-9210393
Ok so just touching the inside of the case every few minutes and I'll be fine?
Woo!
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/723885-static-help/#findComment-9210401
2 minutes ago, QuantumBit said:
Hi!
Thanks!
You should wrap your dog in aluminum foil, then move to carpet and put socks on him and let him build it for you. That should be safe. :D
https://linustechtips.com/topic/723885-static-help/#findComment-9210410
You are on a tiled floor, so you're fine.
Ground yourself by touching the pc case often enough. Keep your dog away from you while building. Grounded PSU means that when your PSU is plugged in, your case is grounded. This is true for all PSU's.
Wearing shoes (or anything buy socks) is a good idea, but since you're not on carpet, don't worry about it too much.
When in doubt, re-format.
https://linustechtips.com/topic/723885-static-help/#findComment-9210415
I build all of my PCs on my bed. I've built a few PCs so far on it and the only time I've had a static problem was on my desk, not related to the building.
https://linustechtips.com/topic/723885-static-help/#findComment-9210418
