Im looking into building my first gaming pc but dont really know what im doing, i have a budget of £450-£500. I will be playing things like Overwatch, CSGO, GTA V, Rust, H1Z1 and any other new releases.
Monitor, peripherals and OS arent needed. I have all that.
All help welcome.
https://linustechtips.com/topic/723807-i-need-a-solid-entry-level-build/
Do you need a keyboard, mouse, OS with it?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  (£63.90 @ Alza)
Motherboard: Gigabyte GA-H110M-H Micro ATX LGA1151 Motherboard  (£39.98 @ Amazon UK)
Memory: Crucial Ballistix Elite 8GB (1 x 8GB) DDR4-2666 Memory  (£47.90 @ Alza)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  (£35.94 @ Aria PC)
Video Card: Sapphire Radeon RX 480 8GB Video Card  (£215.99 @ Amazon UK)
Case: Thermaltake Versa H15 MicroATX Mid Tower Case  (£31.14 @ Eclipse Computers)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.99 @ Ebuyer)
Total: £483.84
Generated by PCPartPicker 2017-01-16 12:48 GMT+0000
Not sure about peripherals, but as the main piece, I'd go for an i3 6300 + RX470. And since it's your first, I assume you don't plan on overclocking, so don't bother with an intel 'k' series cpu, or an overclockable chipset.
You'd be surprised with what you can build for so cheap :)
Ryzen 7 2700x, MSI Gaming X RX 480 8gb, Asus ROG X470 Gaming, 2x8gb Corsair Vengeance LPX 3000, 120gb Kingston SSD (Boot) + 1TB Seagate Barracuda.
Mind doing a pcpartpicker for me? :)
Sure, I'll do that right now, hold up
https://ca.pcpartpicker.com/user/Frankie158/saved/gmTP6h Try that, should open. I put an i5 instead since the budget allowed for it. But you can go one step down to the i5 6400 instead if you wanna save 20$.
You'll be able to run all the games listed at 1080p at max (or at least very close) settings :] It's better then my system, and I can run GTA V 1080p high and stay above 60fps. CSGO I get well over 200 completely maxed out. Should do you just fine :]
Oh and a single 8gb stick will allow you to add another 8gb in the future if you want, which I do recommend within 2017 since games are starting to like more then 8gb :P
You can use the UK pcper website.
Total: £483.84
I would go for an i5 or a i3 for the extra CPU power. Most of the games he plays tend to be CPU bound, so getting a i5 7500 for the extra cores or the i3 7100 for an improvement in base clock with weaker GPU might suit him more.
