Does cable matter for 4k 60hz via HDMI?
Solved by Glenwing,
A basic DisplayPort to HDMI cable will only give you HDMI 1.4, not HDMI 2.0.
In Windows, most likely it is using YCbCr 4:2:0 chroma subsampling to get 4K 60 Hz. You can test it by opening this image; each line of text should only be a single color, but if the text lines appear to have 2 different colors each, and especially if the last two lines appear blurry or unreadable, then chroma subsampling is being used.
Featured Topics
Dan1718 ·
Posted in Troubleshooting0 -
Zexer2020 ·
martixy ·
Posted in Phones and Tablets1 -
CentreMetre ·
Posted in Peripherals0 -
WolfOfValhalla ·
Posted in Graphics Cards8 -
6
10
