Amd driver help
Go to solution Solved by Altecice,
Is this for the BETA 8 drivers? If so everyone seems to have this problem
get it from here like i did: http://www.guru3d.com/files_details/amd_catalyst_13_11_beta7_(13_250_18_october_25).html
I  never had problems with installing drivers with amd cards, but now i do, whenever i start the newly downloaded driver instalation it gives me error.
My laptop + specs
HP 655:
Amd e1 1200 apu with integraded 7310 gpu
4 gb of ram
windows 8.1 preview
Error:
Installer integrity check has failed. Common causes include incomplete download and damaged media, Contact the installer's author to obtain a new copy.
More information at:
http://nsis.sf.net/NSIS_Error
I checked the website they redirect me too, i renamed my installer, i cleared my browsers cache, i even deleted my temp files. What is the cause?
I am using the drivers that they recommended me from the AMD website. HELP please. Or i will install updates from my windows update manager :(
https://linustechtips.com/topic/72352-amd-driver-help/
I don't think so.
I just updated and I have 13.250.18.0.
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/72352-amd-driver-help/#findComment-990772
