Help With GTX 970 Fan
Go to solution Solved by Petoovee,
If you have some sort of syringe you could maybe apply some oil in the gap between the fan case and the fan rotor thingy and let it fall into the motor for an hour or two, wipe and run for an hour on light load, dismounted from the GPU. OpenhardwareMonitor could help you keep your temps in check for that while.
Since you seem to have two fans that is, I'd believe one fan should be able to keep your gpu cold at desktop.
Hello,
I have a Zotac GTX 970 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814500362). Unfortunately, one of the fans feel stiff (?) and its no longer spinning smoothly or as fast as the other fan. I was wondering if I could get some help finding a replacement because I'm having a bit of a hard time finding one (I have no clue actually). I would like the fan to be purchasable on Amazon preferably, but if there's no other option I'm willing to buy it from another website.
https://linustechtips.com/topic/722776-help-with-gtx-970-fan/
Take the fan off and put a bit of oil on the bearings.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/722776-help-with-gtx-970-fan/#findComment-9199399
I've tried doing that, under the sticker it was closed off by what I'm assuming was plastic. Even so underneath that there was no bearing unless I'm missing an extra step.
Sorry about the double post, I'm new here.
https://linustechtips.com/topic/722776-help-with-gtx-970-fan/#findComment-9199417
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
https://linustechtips.com/topic/722776-help-with-gtx-970-fan/#findComment-9199434
I'll give it a shot.
https://linustechtips.com/topic/722776-help-with-gtx-970-fan/#findComment-9199479
