Hi :).
A friend of mine is thinking of designing and making a phone.
Please fill in this survey. Thank you :).
https://docs.google.com/forms/d/e/1FAIpQLSfXxDCEu2lyYv-WVI4ZnRRg2xQn_Eg5ooc4_nL5DawGTHf8Zw/viewform
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/722688-phone-hardware-survey/
3 minutes ago, Wolther said:
Was filling it out.. but then as I was going through I realized I know nothing about arm processors. So I just gave up since my input wouldn't be helpful anyways :P
Same thing. I know. They should rename it to i3 equivalent, pentium equivanent. Much easier
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198495
The SOCs were listed in order of performance with the lower performing at the top and the best at the bottom. You can try again if you want :).
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198503
I've updated the Survey so you can skip the SOC questions if you want.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198533
I think your test is slightly flawed. Samsung and Qualcomm SoCs are often quite comparable.
Also, didn't Microsoft say they'll only support products for 3 years?
Do we get to see the final results?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198563
As long as a Windows phone supports a bare minimum of hardware required by Windows, you can update it and use it.
That's why 1GB RAM is the minimum on the list.
if you have the tab still open then now you can.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198573
Cool. I do think that you need to take the results with many grains of salt though, since the average age of the forum is quite young.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198580
Yeah I am. The results we have were filtered to remove some silly results (people expecting Snapdragon 820 for $200 price point etc).
A lot of people are overestimating the SOC for the $100-150 range though which is quite interesting.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198595
The 625? It probably comes from a lack of knowledge about the product stack.
The 625 is a solid $400 range SoC. Rumored to be in the new Blackberry, hopefully!
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198600
The 625 (14nm) is a newer replacement for the 617 (28nm). The 617 was in $300 and $200 phones last year......
Nah. The 650 lineup is more in that area now. The 65x has become the affordable Snapdragon 8xx series.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198612
13 minutes ago, SCHISCHKA said:
what does this mean?
If someone where to make a phone,  what price points would you recommend they try to tackle.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198687
ok start at the low end so losses are minimised. if you can produce quality at a low price you can attract investment to do more ambitious projects
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198714
I'd much rather have the 625. The 65x suck up battery almost as bad as the 810 on which they're roughly based.
Eh, doesn't really work like that. You'd want to aim for the mid segment or high, as there's usually more margin in those products.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198739
depends on what your doing. i was thinking cheap phones are sold near cost price to customers when they are locked into a telco provider. For example i can get an android phone for the price of a box of beer coz it will only work on vodafone. Theres an opportunity to get a bulk order for your white label/no label product. Many chinese and Taiwan OEMs started out providing no label products to other companies
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198763
It's true that cheaper phones tend to have way worse profit margins and are usually close to breaking even.
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9198880
bump
https://linustechtips.com/topic/722688-phone-hardware-survey/#findComment-9202485
