So this all start one late night extreme 10 hours of none stop overwatch gaming when my PC just quit and turn off. I don't think it was a power surge as everything was working except for my PC. I check the green LED light on my motherboard and it was on as well. I though it was my cpu heatsink but it wouldn't have stop the computer from turning on for at least one second. So I played the waiting game and 30 minutes later she was working again, but for some reason my wireless adapter couldn't pick up anything even my home network was at zero bars and 20 inches away from it. Now does anyone know how to fix this?
Solution tried
Reset Ipv4 and Ipv6 catalog
Reset wireless network
Reset computer
Run intel repair tool (Like I really though you would work :P)
https://linustechtips.com/topic/722670-wifi-problems-please-help/
If you are 20 inch away from it why not use cat5e/cat6 cable?
Magical Pineapples
1 minute ago, RitusDagger said:
I had to move my PC :(
If you have moved it? The cheapest option to fix this problem is to use Ethernet cable instead of wifi, does your phone pick up the wifi signal? If the phone also doesn't pick up the wifi signal this mean is the access point problem if your phone work fine and just your desktop it will be your wifi card on your PC. If you have moved it how far is it away from your networking? such as router or switch.
Magical Pineapples
My phone pick up the signal my computer see only my home wifi and no one else, plus the signal at one bar.
If it one bar, what is your access point? Is like default from your ISP? Also how big is your house?
Magical Pineapples
Just now, RitusDagger said:
the ISP is AT&T and I have no router or extender.
It most likely your router which is your access point as usually those are really poor quality. The cheapest option is run Ethernet cable from that router to your room, if your parent/wife allow you run cable along the bottom or through roof/attic would be preferable as a decent 10 metres Ethernet cable is  cheaper (10-20 USD) than getting new access point or wifi extender.
Magical Pineapples
OK man look I put money into the adapter and I had 60Mbps on full bars, There is no way I would have poor connection and there no way my gaming PC is staying in my living room. I know the cheap way out is a ground connection, but I would love to just have my adapter working again. Also I asked for a solution to fix the adapter not remove it.
Well you could try getting better access point ...such ubiquiti AC lite. You can fix something that can't be fix unless you have stronger access point which output stronger signals. I never really use ISP given gear as they are under powered for what you are paying for, you might able to find something like this ( http://www.ebay.com/itm/6DBi-Omni-directional-External-Dual-Antenna-Indoor-Receive-WiFi-Wireless-802-11N-/331962680322) something like this which in most cases will improve your one bar signal.
After switching from consumer gear for my router/access point is massive difference, no more dead spots and the connection on devices simulations is not crashing the network.
Magical Pineapples
Not helping
6 minutes ago, RitusDagger said:
Not helping
k ... just trying to help.
Magical Pineapples
Solution tried
Reset computer
For those of you who are wondering pass this post I solve the problem. If you don't know this intel wireless adapter have a mini PCIe to PCIe chip format one of the black wire was remove by accident back when I was giving CPR to my PC. Everything work fine now thank you.
