New laptop, opened today. Battery was acting weird ( always said charging 67% even tho it wasn't 67% battery ) and now if I unplug the charger it immediatley dies.
Ideas? Is it screwed?
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/722586-sigh-more-laptop-problems/
Is the battery removable?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Imminently signs of a DOA battery call the vender or ask for a exchange or refund now
I'd definitely return it on the warranty. Saves you all the hassle.
My bets would be that the battery either isn't properly wired or that the battery-charging thingy in the laptop has failed.
67% battery, is it safe to use a multimeter and check the voltages of it?
Scratch that, don't do shit and just return it. Less things they can blame you for the better.
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
8 hours ago, Mug said:
It's new, just return it. I don't see any reason not to to be honest
because i can't be fucked to spend 6 hours redownloading stuff again that's why
Main Rig
CPU: Ryzen 2700X
If you have your downloads saved or in temp then just transfer them to a memory stick and et voilà
transfer via memory stick?
moving that much through a shitty memory stick will take a pretty long time too, not to mention I have to wait another 5 days
Main Rig
CPU: Ryzen 2700X
Yeah, I'd return it also.  But looking at previous posts, it seems you can't be arsed.  I don't know, stay stuck with it then and have an immobile laptop.
The Full Pounder Korbger (main PC):
CPU: AMD Ryzen 5 7600X | CPU Cooler: Deepcool AK500 ZERO DARK | MOBO: Gigabyte B650M AORUS ELITE AX | RAM: G.Skill Flare X5 32GB DDR5-5600 | Storage: Kingston NV2 1TB NVMe SSD, 2x Inland Professional 1TB SATA SSDs | GPU: ASRock Challenger Radeon RX 9070 | Case: Fractal Design North | PSU: Montech CENTURY II 850W 80+ Gold
Sheer Will and Spite (home server):
CPU: AMD A10-7870K | CPU Cooler: Stock AMD Cooler | MOBO: ASRock FM2A88X PRO3+ | RAM: Crucial 16GB DDR3-1600 | Storage: Kingston SSDNow S50 16GB SSD, Crucial MX100 512GB SSD, Seagate BarraCuda 2TB HDD, Western Digital Blue 2TB HDD, Seagate BarraCuda 1TB HDD, Seagate 1TB hybrid drive | GPU: Sparkle ECO Arc A310 | Case: Apevia X-Plorer | PSU: Thermaltake Smart Pro RGB 750W 80+ Bronze | Expansion Card: VOGZONE 2.5Gb PCIe Network Card
The Curb Stomp Coin-Op (MAME Machine):
CPU: AMD Ryzen 5 1600 | CPU Cooler: AMD Wraith SPIRE | MOBO: Gigabyte GA-AB350N-Gaming WIFI | RAM: Patriot Signature Premium 16GB DDR4-2666 | Storage: PNY CS900 240GB SSD, Samsung 860 Evo 2TB SSD | GPU: Gigabyte GeForce GTX 1050 Ti | Case: Homemade Arcade Cabinet | PSU: Corsair RM750x 750W 80+ Gold | Monitor: ONN 21.5" 1080p 100Hz Freesync
Bazzite Box (HTPC):
CPU: AMD Ryzen 5 3600X | CPU Cooler: Wraith Spire | MOBO: ASRock AB350 Gaming-ITX/ac | RAM: Corsair Vengeance RGB 16GB DDR4-3000 | Storage: WD Black SN770 1TB NVMe SSD | GPU: PowerColor Fighter Radeon RX 6600 XT | Case: PowerTrain X-GAMER X100 | PSU: MSI MAG A650BN 650W 80+ Bronze
Right... So you'd rather potentially void your warranty and still possibly not repair it than do 6 hours of downloading and getting things ready. Like get your priorities in order. Clearly, you were sold a defective unit so you need to get it sorted out. I'm surprised that there's even a question in your mind about sending it back. This isn't your fault.
If you have the know-how (not that it's really hard to do, but I always forget how so takes atleast half an hour), transfer it through your LAN. Any router within the last five years should have at least 100Mbit.
That beats even USB3 doesn't it?
Either way prolly beats ye HDDs unless you downloaded 6 hrs of movies or smtn.
EDIT:
You can use Bittorrent sync! That'll get you sending it through your LAN in no time!
Maybe even get you going on that continuous backup schedule so you can just reset your computer once a season without hassle!
EDIT2: With a HyperX Savage and a 1070 I expect you to have a gigabit router tbh :P
CPU - Ryzen 7 2700x
GPU - RX Vega 64
HDD - WD Black 4TB
Sending it back :/
Fucking asus dude, first asus product and my last.
Main Rig
CPU: Ryzen 2700X
