Hello!
I'm going to build my first gaming pc soon. My maximum budget is 900 euros. I also need to buy monitors and keyboard inside this budget.
I'm from Estonia, so I expect to buy all my parts from one Estonian shop, to avoid any struggle with taxes and shipping. The link of decent Estonian components shop is here https://www.galador.ee/  I'm adding it just in case. Keep in mind that components are more expensive here than in US.
Can you judge my current choise of parts?
I'm going to play on 1080p and I play games like batllefield 4, gtaV, Age of Empires III and CS-GO.
Thank you!
https://linustechtips.com/topic/721788-first-pc-build/
27 minutes ago, Aleksiandrovich said:
how much is the RX 480? if you can make some compromises i would do it in order to get the bump from 470 to 480 - it is well worth it.
I could make a compromise and get GPU from amazon GB or DE.
I also saw that I need to buy the i5-6500 that is boxed, so I could get the cooler. I chose the tray version by accident.
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9187948
Looks alright. Personally, I'd change that monitor to a FreeSync one: https://www.galador.ee/1230-monitorid/3449394-monitor-aoc-g2260vwq6-21-5inch-d-sub-hdmi-dp
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9187954
It looks awesome. However, I've never heard of that keyboard brand, and it looks like a membrane keyboard. See if you can find a cheap mechanical keyboard in your area; it's well worth it.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188068
Thank you! It's some cheap Eastern-European brand. I highly doubt they sell these outside Eastern-Europe region, that's why you have probably never heard about it. I will look for mechanical keyboard. @Aereldor
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188879
I just want to add: you can buy either version of the CPU but I would NOT use the stock CPU cooler.  They are junk and a good CPU cooler isn't very expensive, you can get a Cooler Master Hyper 212 EVO pretty darn cheap and while it's BIG (make sure it fits in your case) it will perform *significantly* better.  It should also come with some thermal paste, but you can get some Arctic Silver V for a few euros without any trouble.
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188917
I will consider it. I know the stock one can be pretty loud. @aithos
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188931
It's not just that it's loud, the thermal pad that comes with it is really poor for transferring heat and they just don't cool very well because they are tiny.  I don't know the price in Euros, but the cooler I mentioned is about $35 so we aren't talking about a lot of money to get something that will perform several times better AND will increase the overall lifespan of your build.  Heat is the enemy!
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188987
Yeah that makes sense. It's not that expesive either. @aithos
https://linustechtips.com/topic/721788-first-pc-build/#findComment-9188993
