Hi.
So I've been recently looked into modifying my MasterCase 5 Pro, and got a lot of recommendations on using the NZXT's Hue+ with the 4 RGB strips.
And beyond that I was also looking to upgrade my case fans and thought the Corsair's 120mm ML120's would do justice for the build. But then I stumbled upon a problem.
See, I want my case to be well lit as the result of this build, so I'd like to know, should I go for the ML120 which have white lighting on them, or should I just go with the regular ML120 without any lighting? Does the lighting of the fans have big impact on the rest of the case lighting?
-Sebbyy
https://linustechtips.com/topic/721784-question-relating-to-case-lightings/
