Hello.
I recently got a Bitfenix Prodigy M (For Free!). As you know the motherboard header cables are detachable from the actual connectors on the case as they are on the side panel. My problem is this. The cable for the audio jacks is missing (The HD audio header on the motherboard)
How would I go about getting a replacement? I don't care about if it is all black or ketchup and mustard as there is no window, also I live in the UK.
Thanks in advance
https://linustechtips.com/topic/721476-hd-audio-cable/
