Hard drive erase
Solved by Mira Yurizaki,
17 minutes ago, orangebeaver45 said:
This looks like the option in the Reset feature, which, while it will erase everything off the HDD, Windows will reinstall itself onto it.
If you don't want anything on the HDD, plug it into your new computer and reformat it. If you really want to make sure everything's erased, use a secure erase tool (CCleaner has one)
