so i ruined my pc long story short involved milk lul, so im nuilding my first one.
i have bought most of the parts already and just need advice on couple things.
1: I have this guy who has a 4.8 hhz i7 6700k he wants to sell me for around 370 it was used on a benchmark for 8 hours and other benchmarks then put back in box ... i dont know if i plan to overclock or not should i buy it over a new 6700k
2: is there anything specific i need to know going forward
3 does the brand of ssd matter i have a weird amd brand ssd should i gte another one
specs
ram:32 gigs of 2666 ghz ddr4 corsair dominator platinum
motherboard:z170 pro asus
drives:one firecuda 1tb r3 amd ssd 120 gigs might buy samsung here soon
psu:750 watt thermaltake grand
cou: i7 6700k
case: phanteks evolv atx temperd glass
cpu cooler: its a phanteks sone i forgot which one tho
(some of these havent been bought im just getting opinions first and advice)
thanks in advance
https://linustechtips.com/topic/721276-first-build-need-helpadvice/
You're chilling with that ssd, if that cpu works i cant find a reason why not to buy it if its under avarage price of a new one
Never heard of that psu tho.. im not that much into psupplies but check psu tier list . if its in top 3 tier you are good because this is kinda high end although you forgot to list gpu
GPU: GTX 1060 6GB
RAM: 16GB HyperX RAM
CPU: R5 3600
Motherboard: ASRock B450 Fatal1ty gaming K4
OS: Win 11 Pro 64-bit
http://www.thermaltake.com/products-model.aspx?id=C_00002989 thats the psu and im going to buy gtx 1070 i figured the 1080 is overkill for me I think.
its approx 30 dollars more
