Hi there, this is my first post on this site and In thought I would start off with my h440 build. I have various mods that I am going to work on in the coming weeks, Including a full custom water cooling loop and a custom front panel. I have a few other bits and bobs like getting a new power supply so I can get sleeved cables easily as my current one is basically impossible, this will allow me to clean all my cables up a bit better ( as extensions make it a mess). Also custom painting a few components.
Specs:
Hero Maximus vii
g1 gaming 1080
6700k
evga g1 650w
2 kingston 240gb ssd
2tb wd black
corsair h115i
16gb corsair veng ram
So currently running this build, Below I have 2 drawings outlining a couple of my plans as previously mentioned.
So below is my planned parts list, please let me know if you would recommend anything else or have any helpful suggestions.
EKWB EK-XRES 100 Revo D5 pump/res
2x 360m ek coolstream rads
EK supremacy Evo cpu block
Ek G1 1080 block and backplate
primochill flexi red tubing
Ek 1/2 inch fittings and a ball valve drain port at the lowest point
Corsair sp120s
This is the rough layout for front panel I want to do. As in pic I want the 3 front fans outside of the main section of the chassis sitting inside the front panel (checked clearance already). Also as mentioned it will sitting right on the border or slightly over the edge of the red ring on the corsair fans. I am undecided on what to use as the material to fill the gap with. I have a few options including using modders mesh then somehow fitting as dust filter behind, using some custom dust filter to fill the gaping hole or somehow reuse the including nzxt dust filter.
So these are my plans, please feel free to give me any feedback on my plans. Also help me with a name!!
Peace!!
https://linustechtips.com/topic/721191-project-red-fang/
Welcome to the forums!
Liquid cooled builds are always cool to look at. But also since the H440 isn't an amazing case for air cooling, the custom loop will completely do away with any problem with temps that you would otherwise have.
All I can tell you is to remember to still keep the airflow path relatively straight inside your case, so that your motherboard's components like the chipset, VRMs, and RAM have access to moving air to keep them cool. Same for hard drives, have some air moving through them too.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/721191-project-red-fang/#findComment-9181384
Hey man thanks!
Yeah with 3 decent fans running up front i should still have plenty of airflow over the rest of components.
https://linustechtips.com/topic/721191-project-red-fang/#findComment-9181494
