Is there a way to turn down my fans?
KJ4
So i recently bought an MSI H81M-E33 Motherboard for my PC, and when i try and turn down the fan speeds in my pc, the lowest it goes is 50%, and even though my CPU cooler and rear fan are fairly quiet, my front fan is really loud and if i want my pc to be quiet i have to disconnect my front fan, which could make air flow a little worse. I have tried looking up ways to decrease the percentage of the fan speed, but i cant find anything that actually works and is still stuck at 50%.
Try Speedfan.
Also is your front fan being powered by molex or a 3/4 pin on the motherboard?
PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD   PSU Corsair CX750M - Cooling Stock - Case White NZXT S340
Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL  Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter
What fan is it and what header are you plugging the fan into?
You could use a fan controller instead that individually controls each fan. Google for fan controller and look up one that fits your demands.
Okay i will have a look right now.
It is the system fan 2 header, and i have plugged my other front fan in and it is much quieter. The fan i am currently using is an Arctic X12 120mm.
8 minutes ago, ImperialSteele said:
You can limit them in BIOS
Edit: Depending on MoBo
Yeah, it doesn't allow me to go lower than 50, which is why i want to get my front fan to a lower speed.
What motherboard do you have?
12 minutes ago, RKRiley said:
Try Speedfan.
It is a 3 pin header.
MSI H81M-E33
1 minute ago, KJ4 said:
MSI H81M-E33
Sys_fan2 is just a powered header with a 12v signal which will run the fan at 100%. It offers no form of control and you should get a splitter to run off of the other two headers if you want control.
Okay, thanks for your help :)
