Save a bit more and get a Cryorig H7, better looks, quieter, and better cooling. Get it from Amazon or Newegg so if it doesn't fit you can return it.
beQuiet Pure Rock is also a good idea
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9172629
19 minutes ago, toooby said:
I have a micro ATX motherboard (gigabyte h110m-a) and I wanted to upgrade the cpu cooler. I found a hyper 212 evo for 15 dollars but I have been worrying that I might have some clearance issues with my ram (G.SKILL Ripjaws V Series).
you shouldn't have a problem with clearance on that board as it seems that the ram slots closer to the cpu socket have been removed instead of the other way around
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9172691
hahah I think I have too because I cant find the evo on offer up anymore :/
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9172715
Looking at a sample picture of it, the RAM is nearly the same length of the CPU itself away from the socket. Also, the size of the cooler shouldn't go much further past the mounting points either. But in saying all this, if you want to be safe than sorry you should either take the risk or look at their returns policy.
The specs say 120 x 80 x 159 mm (4.7 x 3.1 x 6.3 in) on the cooler, so why not just measure it just in case?
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9172737
will do! :)
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9172757
11 hours ago, fiberzs is dad said:
*shoulden't
There's an edit button btw.
The cooler fits just fine. You can always just mount the fan on the other side in pull.
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9175200
H7 will clear any height ram you want and perform better than Evo 212
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/720453-aftermarket-cpu-cooler/#findComment-9181293
