Programs appear on my secondary monitor
Grishnaackh
Hello everyone.
I just got a second monitor for my setup. I have changed my default monitor to the desired one but programs still insist on opening on my secondary. How do I fix this?
For some I believe you open it move it to the desired monitor, close it. Reopen it and it should be on the correct one. Not for all applications tho.
Display Fusion may have a function for this as well....
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
Thanks! I'll check it out.
