Recently my droid turbo battery has been very be, like I would up 2 hours ago and it's at 78 percent, and I only watched like 5 YouTube videos. I used to be able to get through the day with 60 percent left, now it's 30-40, and it only just started happening so I don't think it's deterioration because it wasn't gradual, should I just do a factory reset and see from there?
https://linustechtips.com/topic/720249-phone-battery/
4 hours ago, Aniallation said:
What are the battery usage stats? Is there an app draining your battery more than usual or causing a wakelock? I remember updating to the latest version of Facebook on my Priv and it cut the battery life in half -.-
Nope, just screen, wifi, and standby using the most. I'll try recalibrating my battery when I'm out of school like the tohers suggested
https://linustechtips.com/topic/720249-phone-battery/#findComment-9171608
