The Bitfenix Prodigy M
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-985264
Bitfenix Phenom micro atx is better ¬¬
They are based off the exact same chassis .-.
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-985295
Yeah, but da phenom doesn't have that shopping bag feet
Best argument ever... *clap* *clap*
But seriously, the Phenom M and Prodigy M are the same. Different exterior, same interior. In the end, the Prodigy will have MUCH BETTER AIRFLOW (black version) since the front panel actually has some decent perforation.
OP, go with the Prodigy M or the Corsair 350D if you don't like a hot machine.
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-985323
Intel Core i7-8700K @ 4.8GHz | Corsair H110i GTX | EVGA RTX 2080 XC | Asus ROG Maximus XI | Intel M.2 nVME SSD 1TB | Samsung 850 EVO 2X2TB | 32GB G.SKILL Trident Z 3200MHz CL14 RAM | EVGA SuperNova GS 1050W | Kept cool & quiet in a Fractal Design Define R5 Window with all Noctua fans
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-988267
Looking for a small mATX case that is clean looking and has five expansion slots
OP looking for 5-slot PCI not four.. ive looked for the same and the Prodigy mATX
and 350D are what i came a crossed. i have just built the 350D with a Rampage IV
Gene and i7-3820. still working on it, jury is out. honestly, i don't feel either case is
stellar but i/we will see.
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-988610
  • 8 months later...
I know I am months too late however the Fractal Node 804 is also an option. It is larger than the Bitfenix cases (prodigy, phenom and colossus) however it is better optimized for airflow and has all of its fans guarded with dust filters. So its something to consider.
https://linustechtips.com/topic/71954-a-five-slot-matx-case/#findComment-2433844
Guest
