CPU runs hot
Go to solution Solved by Hecknologist,
Definitely increase the airflow in your case, if that isn't enough to get your temps down then you probably should get a new cpu cooler. Plenty of recommendations for coolers in the appropriate section of the forum.
Yo LTT'ers
My AMD A6 5400K runs at 60 degrees Celsius at IDLE  :o and reaches TJ MAX at load, i have tried even turning volts and clock down to stock and i still get the same, i have swapped out different thermal compounds the cooler master and the generic paste (they spell cooler like pooler?!) and still the same, the heatsink fans are drawing air from the graphics card pcb and exhausting into the psu, my only exhaust. My only intake is my fan at the front which runs on 5V and move like nearly zilch air.
QUESTIONS:
Should i buy some Arctic Cooling MX-4,
should i buy a new 120mm case fan Noctua s12 or p12
should i re arrange my case fans ( would adding an exhaust starve my top mounted psu of air?)
Thank you...
Main: AMD Athlon X4 750K| Coolermaster Hyper TX3 EVO | Gigabyte GA-F2A75M-HD2 | 8GB Kingston 1333mhz | WD Caviar Green 1tb | Coolermaster N200 | OCZ coreXstream 500w | Sapphire Radeon HD 7850 2GB | |Kingston 3k ssd 128gb |
https://linustechtips.com/topic/71909-cpu-runs-hot/
Noctua NH-U12S Should be enough
Not buying an new cooler and my case does not support it.
https://linustechtips.com/topic/71909-cpu-runs-hot/#findComment-984601
What case do you have?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/71909-cpu-runs-hot/#findComment-984603
Fractal design core 1000 notg much clearance cant even fit a hyper 212 :(
https://linustechtips.com/topic/71909-cpu-runs-hot/#findComment-984610
Will do, gonna order my Noctua now.
https://linustechtips.com/topic/71909-cpu-runs-hot/#findComment-984611
Try an AIO liquid cooler. Or something low profile such as the NH-C14 by Noctua.
Cpu: Intel i5 3570k @4.3Ghz *cooled by Thermaltake Water 2.0 Extreme* | Case: Bitfenix Prodigy-M | Motherbord: Asus P8Z77-M Ram: Patriot Viper 3 8gb @1600mhz | Video Card: Asus HD7870 @1180/1300 |
Power Supply: Corsair HX650 Monitor: LG 22EN43 | KeyBord: CM Storm Quickfire Rapid  | Mouse: Corsair M60 | Sound CardCreative Sound Blaster Z|Headset : Audio Techinca ATH-M50 |
Storage : Sandisk Extreme 120gb and 1tb Seagate Barracuda |
https://linustechtips.com/topic/71909-cpu-runs-hot/#findComment-993789
