It should be fine, i only using one PCIE cables which goes into two 6+2pin PCIE for my 980ti and have been running fine for well over 9 months.
Magical Pineapples
https://linustechtips.com/topic/718393-gpu-power/#findComment-9150933
Alright cool,do you know how xpu power can work because my motherboard is a bit iffy on the actual connector as the connector doesn't actually fit and yes it I was putting it in the right way as well as tried other directions
But the power supply comes with an adapter that allows me to plug in a 8 pin cable that adapts to two other 8 pins that I can plug kntonthe motherboard but the motherboard only has one cpu power slot so I'm not sure if it is safe if one side of the cable isnt be used
https://linustechtips.com/topic/718393-gpu-power/#findComment-9150984
