so right now i have this https://www.amazon.com/gp/product/B01EFIQ91G/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 (got it on a amzon lighting sale for $6)
and I like it and all but the only complaint is the "mode" option
when you press mode on the controller it will cycle through the modes, like breathing, flashing, strobing, quick single flash, and color cycle.
and thats good and all but the only thing I dont like is that when you pick a mode, so say i pick breath it will go though every color in the "breath cycle" then it will change to the next "mode" like single flashes, it does not stay on the mode you pick. it cycles through all the modes,
(this is all done via physical controller built into the base of the strip)
so im looking for a pre cut led strip that will allow me to pick a "mode" and stay on that mode untill I switch it, and yes an RGB LED strip. biggest thing is i want a color cycle mode.
https://linustechtips.com/topic/718310-led-strip/
1 hour ago, Darrenl81 said:
They aren't really cheap, but they are used by many
Honestly if it's in your pc go with cable mods led strips, high quality, and you can if you are desperate runs cable out the back of pc to power it externally
id prefer to have that is powered via USB or molex i dont have enough open outlets for anymore things to be plugged in lol. and yes it is inside my pc
https://linustechtips.com/topic/718310-led-strip/#findComment-9150037
  • 4 weeks later...
Hey @Jamtoad, have you taken a look at the CableMod WideBeam RGB strips? If you purchase a kit you get an included controller similar to the one you have been using.
Plus, if anything ever became faulty, we replace it free of charge to you.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Dcomputers&field-keywords=cablemod+widebeam+magnetic
https://store.cablemod.com/products/?filter_series=magnetic&filter_product-category=led-strips&filter_color=rgb
https://linustechtips.com/topic/718310-led-strip/#findComment-9308051
