So I have a budget of roughly $500 to spend, with a max of $600 on a computer. Desktop of any size is alright.
Here's what It MUST have.
-A monitor of 20" minimal
-Wifi
-And a copy of windows (preferably win 10, i know its trash)
and thats it.
I will be playing games ranging from Brawlhalla all the way to GTA V, I know its a strech to pull off but I'm looking for outside help. Ive already built some builds on PCPP but like I said, outside input is something I'm looking for!
Thanks for the help
-PhilMoreJenkins
https://linustechtips.com/topic/718004-i-need-some-help/
-Wifi
and thats it.
Thanks for the help
-PhilMoreJenkins
What is the build you made already?
https://linustechtips.com/topic/718004-i-need-some-help/#findComment-9146444
For that budget, with a screen and capability of playing GTAV, you are going to have to see whats available USED around you.
If gaming isn't a concern, literally anything you can find will do just fine.
When in doubt, re-format.
https://linustechtips.com/topic/718004-i-need-some-help/#findComment-9146516
