2 minutes ago, Himommies said:
Like first of all because of your cpu that slot can only run at x4 speed anyways i dunno why it would be set to x1
I believe the x1 mode is a limitation set by the manufacturer?
Folding stats
Vigilo Confido
https://linustechtips.com/topic/717954-pcie-x1-mode-problem/#findComment-9145821
2 minutes ago, pwn_intended said:
The intel J1900 only has 4 PCIe lanes to begin with.
That motherboard's x16 slot is only wired for x1 mode. So you COULD use a GPU in there but it will woefully underperform.
So this is a built-in limitation or can I at least change it to x4 mode or something?
Folding stats
Vigilo Confido
https://linustechtips.com/topic/717954-pcie-x1-mode-problem/#findComment-9145851
It's a physical limitation. The slot only has enough pins for PCIe x1.
https://linustechtips.com/topic/717954-pcie-x1-mode-problem/#findComment-9145862
Its not really a built-in "limitation" so much as a design choice for that CPU. It is not intended to be used in systems with high performance PCIe cards in it.
Short answer, no. A PCIe 1x slot is a PCIe 1x slot. (it is physically x16, only to allow for larger cards to physicaly fit, but they will only run in 1x mode)
When in doubt, re-format.
https://linustechtips.com/topic/717954-pcie-x1-mode-problem/#findComment-9145879
