Just now, Roi said:
Hey guys, im doing a build and im wanting to know if the Cooler Master Hyper 212 LED will fit into the Thermaltake view 27. Thanks in advnace!
don't think so it is too tall
6600K - ASUS Z270i Gaming ITX - 8GB Corsair  Vengence LPX DDR4 2400MHZ - EVGA 1070SC - 120GB HyperX Savage SSD - CX430 PSU:|
PSU tier list-
Just now, Roi said:
dam, i just looked up the specs. the case allows 155mm and the 212 is 6.3 inches :(. anything you recommend that isnt going to break the bank? im thinking an AIO water cooler now.
maybe a noctua u12 is shorter
PSU tier list-
When I had this cooler I put it in a corsair spec 01 (I said it didn't fit) but it did
well i already have the case and the cooler. im just waiting on the MOBO and ram to show up. i dont know why i didnt look this up before hand. good thing is that the 212 is only like $35 so im not out that much. now im looking into a AIO system. maybe a corsair?
Don't open the 212 evo and send it  back
13 minutes ago, Roi said:
anything you can recommend for water cooling?
120mm aio's are not worth it
PSU tier list-
