I am looking for the best micro usb cable that is 9ft in length for my gear vr. The cable must power the device and allow data transfer. Also is their a limit? I need the cable to work really nice. Another thing that will be nice is a tangle free braided cable. Please use amazon.
Thanks!
Tech enthusiast and CS Student
https://linustechtips.com/topic/717148-best-9ft-micro-usb-cable/
I've never had a Braided cable fail on me. Braided also means more ridged so no tangling. I've only bought cheap braided Micro USBs 2-3$ ones, has not burnt out yet from fast charging so it's an adequate cable at least, so a more expensive one would be even better.
Just if they are going through the trouble of making the cable braided then they probably won't be crap wires inside. Just my 2 cents.
https://linustechtips.com/topic/717148-best-9ft-micro-usb-cable/#findComment-9136763
