36 minutes ago, danielhowk said:
im planning to buy samsung 960 pro 500gb,im wondering if theres any issue with samsung 960 pro 500gb version?
previously the samsung 950pro have some thermal throttling problems.
none that im aware of, but maybe you could try google or samsung forums?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/716722-samsung-960-pro-problems/#findComment-9132002
The 950 Pros only had thermal throttling issues if you were constantly hammering the drive.
https://www.pugetsystems.com/labs/articles/Samsung-950-Pro-M-2-Throttling-Analysis-776/
http://www.anandtech.com/show/9702/samsung-950-pro-ssd-review-256gb-512gb/12
Also, unless you have something that needs the bandwidth, don't bother with an NVMe drive. Most consumer applications don't even come close to saturating the bandwidth provided by SATA 6Gbps.
https://linustechtips.com/topic/716722-samsung-960-pro-problems/#findComment-9133995
Depends on your usecase i guess?  If you're constantly editting and transferring 50+gb files around and zipping/unzip ginormous amounts of data, it will make a difference.
In some cases it has cut install times for large games in half or even more.  A second here, a second there, it all adds up to a better experience and overall lower perceived lag.
Not to mention clearing up the clutter inside your cases - saving a drive bay and 2 cables is always a good thing.
I'm not an expert! In fact I'm usually just 1 google search ahead of you.
https://linustechtips.com/topic/716722-samsung-960-pro-problems/#findComment-9134058
Unless you're installing from the NVME drive itself, install time limited to the media from which you are installing.
And if your life is literally dictated by the amount of seconds you save, I think you have more things to worry about than a game loading a second faster.
And if it's online, you're going to be held back by the other players anyway.
EDIT: Ultimately here's why I think a SATA SSD is worth more than an NVMe SSD: You get more space with a SATA SSD. While this may sound like a "duh" situation, here's why it's better. SATA to NVMe produces marginally better results than going from an HDD to a SATA SSD. But an NVMe SSD usually costs twice as much as a SATA SSD for the same capacity. I would rather be able to store more things on an SSD with the much noticeably faster load times than go with something that may improve it further, but slightly so, and lose half the capacity.
https://linustechtips.com/topic/716722-samsung-960-pro-problems/#findComment-9134147
