Well the 970 is only like 180$ at microcenter so getting them in sli is an option sooner than later
3 minutes ago, deXxterlab97 said:
Eh. A 1060 is at the level of 980 so getting a 970 is a bad choice.
See for used cards if you want to maximize performance like R9 Fury/Fury X
https://linustechtips.com/topic/716495-new-card-ideas-help/#findComment-9129459
Fury (X) wouldn't be a bad idea, personally though I would go for an RX 480 as the driver updates have shown very promising increases in performance and it is basically on par with the 1060 at DX11 and destroys it in DX12 and Vulkan. I wouldn't buy a 970 as it is barely holding on to its lead over the RX 480 and will start to fall behind as time goes by due to lesser support for older architectures.
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
https://linustechtips.com/topic/716495-new-card-ideas-help/#findComment-9129475
8GB RX 480, a refurbished/new R9 Fury or a used Fury X
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/716495-new-card-ideas-help/#findComment-9129553
A 1060/480 are ahead of a 970 for sure. A 970 I would say is more or less closer to a 3GB 1060 and ahead of a 4GB RX 470
https://linustechtips.com/topic/716495-new-card-ideas-help/#findComment-9129556
