13 hours ago, Yuriysama said:
snip
You created the variable but didn't assign it a value.
For instance you did
command = "buyfood"
description = "Buy food."
delay = 1.5
You may have never assigned a value to "buyfood"
OR.. your code above doesn't have a closing curly brace. If it is part of the buyfood error then that may be your other problem.
I have limited Lua knowledge but I know a bit of C++. (Lua was based off C++)
https://linustechtips.com/topic/716407--/#findComment-9131659
On ‎1‎/‎3‎/‎2017 at 6:32 PM, Yuriysama said:
Hi fpo,
Thanks for your reply.
The command works when hungermod is enabled, I only get this issue when hungermod is disabled in DarkRP.
I've tried posting on facepunch but it seems nobody is able to diagnose the issue there either.
Hey I didn't see your reply. Try quoting me or putting the @ symbol before my name. For instance "@fpo"
I'll analyze your reply in a bit. I have a bit of a drive so if I don't finish my reply I'll send it later.
https://linustechtips.com/topic/716407--/#findComment-9148031
On 1/3/2017 at 6:32 PM, Yuriysama said:
Hi fpo,
I'm going to need more code. In your question the phrase "hungermod" is nowhere to be found in code.
If I were to guess there is a loop or control flow somewhere that checks if "hungermod" is disbled. For instance:
if (!hungermod) // also works as (hungermod = false) or (hungermod != true) or other varients. I don't know the Lua syntax but it should be similar
	then
		declareChatCommand();
end if
If the code works with hungermod enabled, then try and work your code so it stays enabled.
https://linustechtips.com/topic/716407--/#findComment-9149545
