I have been having this problem for a while now where my PC randomly crashes (restarts mostly) whilst I'm running demanding games.
Games this effects me in is >Dark souls 3>Battlefield 4>GTA 5>Warframe>Fallout 4 (Modded). Although when I turn down settings to very low/720p in dark souls, it seems to fix this issue, which tends to crash the most out of all the games I play.
My pc Specs are
Windows 7 64bit Home premium
Corsair CX 750W PSU
Gigabyte GTX 960 (4gb) GPU
AMD 8320E CPU ( ARCTIC Alpine 64 GT Rev.2 cooler)
Asus M5A97 MOBO
One WD 1tb hdd running windows and games
One Seagate barracuda 1Tb backup storage
In a Zalman Z11 Plus case.
5 case fans
All temps seem to be running fine whilst in games, never exceeding over 70degree's on any component from what I can tell.
All parts are regularly dusted.
I have tried updating drivers and all that goodness. cranked fans up to keep everything cool, but nothing I do seems to stop the crashing other then turning graphics down to xbox 360 levels.
I have unchecked all settings in windows that restarts pc after an error > all power settings are at high performance or similar.
If anyone has any ideas on what could be causing these crashes I'd be extremely grateful. Thanks LTT peeps
https://linustechtips.com/topic/716386-kernel-41-power-error-please-help/
My pc Specs are
Corsair CX 750W PSU
Asus M5A97 MOBO
5 case fans
That is a VERY generic error message.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
I can try another psu although its only 500w so I'm not sure if it would be capable.
It has NOTHING to do with power.  Please see video.
